Group: DynoMotion Message: 7170 From: fireup_kev Date: 4/2/2013
Subject: V4.31b Fixture offset table not saved right
Seems like the Fixture offset table added in V4.31b is not being saved right. G54 and G55 seem to corrupted each others data.
Group: DynoMotion Message: 7171 From: Tom Kerekes Date: 4/2/2013
Subject: Re: V4.31b Fixture offset table not saved right
Attachments :
Hi Kevin,
Right again.  In GCodeInterpreter.dll file driver.cpp
this
    int index = settings->origin_index;
    Vars[5221+index*20] = settings->origin_offset_x;
    Vars[5222+index*20] = settings->origin_offset_y;
    Vars[5223+index*20] = settings->origin_offset_z;
    Vars[5224+index*20] = settings->AA_origin_offset;
    Vars[5225+index*20] = settings->BB_origin_offset;
    Vars[5226+index*20] = settings->CC_origin_offset;
should be
    Vars[5201+index*20] = settings->origin_offset_x;
    Vars[5202+index*20] = settings->origin_offset_y;
    Vars[5203+index*20] = settings->origin_offset_z;
    Vars[5204+index*20] = settings->AA_origin_offset;
    Vars[5205+index*20] = settings->BB_origin_offset;
    Vars[5206+index*20] = settings->CC_origin_offset;
I have also attached the changed file.
Group: DynoMotion Message: 7172 From: fireup_kev Date: 4/2/2013
That fixed the offset table for G54 to G59.9, but the global G92 offset is not being saved. Is this intentional or should that be saved also?
Kevin
> Hi Kevin,
> this
> should be
> Sent: Tuesday, April 2, 2013 5:21 PM
> Subject: [DynoMotion] V4.31b Fixture offset table not saved right
Group: DynoMotion Message: 7173 From: TK Date: 4/3/2013
Hi Kevin,
I think the code is working correctly but it is somewhat confusing.
The current Interpreter State (including offsets) can be saved to the Vars File. The Setup File allows you to force the initial state of things to specific values.
I think the default setup file - default.set - sets the xyz G92 offset to zero.
If you would rather the offsets to be saved rather than set to specific values then remove the settings from the Setup File.
Kevin
> Hi Kevin,
> this
> should be
Group: DynoMotion Message: 7174 From: fireup_kev Date: 4/3/2013
Ok, after I remove the values from default.set it kinda works. I can save the values for G92 if I use the Zero or Set button next to the DRO but can not change the values in the table directly like I can for G54 to G59.9 (but I think it's fine the way it is now, maybe remove the clear button for G92 since it cannot be clear that way)
(you should also update the help...)
Kevin
> Hi Kevin,
> > Tom,
> > Thanks,
> > Kevin
> > --- In DynoMotion@yahoogroups.com, Tom Kerekes <tk@> wrote:
> > > Hi Kevin,
> > > this
> > > should be
> > > Regards
> > > From: fireup_kev <kliboon@>
Group: DynoMotion Message: 7176 From: Tom Kerekes Date: 4/3/2013
Kevin,
Yes several bugs regarding applying/saving G92 offsets from the Edit Fixtures Screen.  Here are two files with changes that should fix them.
Group: DynoMotion Message: 7180 From: fireup_kev Date: 4/4/2013
So far so good with these updates. Can we make a V4.31c so I have an install version with all the latest changes?
> Kevin,
> Sent: Wednesday, April 3, 2013 6:28 AM
> Subject: [DynoMotion] Re: V4.31b Fixture offset table not saved right
> Thanks,
> Kevin
> --- In DynoMotion@yahoogroups.com, TK <tk@> wrote:
> > Hi Kevin,
> > On Apr 2, 2013, at 9:53 PM, "fireup_kev" <kliboon@> wrote:
> > > Tom,
> > > Thanks,
> > > Kevin
> > > > Hi Kevin,
> > > > this
> > > > should be
> > > > Regards
> > > > TK
Group: DynoMotion Message: 7181 From: fireup_kev Date: 4/5/2013
I also added "KM_dotnet_Interop_GCodeInterpreter_SetVarsFile" and
"KM_dotnet_Interop_GCodeInterpreter_GetVarsFile" so I can set the "emc.var" to a different directory via .NET
> > Kevin,
> > Thanks,
> > Kevin
> > > Hi Kevin,
> > > Regards
> > > > Tom,
> > > > Thanks,
> > > > Kevin
> > > > > Hi Kevin,
> > > > > this
> > > > > should be
> > > > > Regards
> > > > > TK
Group: DynoMotion Message: 7182 From: Tom Kerekes Date: 4/5/2013
Hi Kevin,
Can you send me the changed files?
Group: DynoMotion Message: 7183 From: fireup_kev Date: 4/5/2013
I made a folder in the file section called V4.31c with 4 files that I changed.
> Hi Kevin,
> Thanks
> Sent: Friday, April 5, 2013 7:05 AM
> > > Kevin,
> > > Regards
> > > Thanks,
> > > Kevin
> > > > Hi Kevin,
> > > > Regards
> > > > TK
> > > > > Tom,
> > > > > Thanks,
> > > > > Kevin
> > > > > > Hi Kevin,
> > > > > > this
> > > > > > should be
> > > > > > Regards
> > > > > > TK
Group: DynoMotion Message: 7184 From: Tom Kerekes Date: 4/5/2013
Hi Kevin,
Thanks!  Here is a New Version with the fixes for the KMotionCNC Edit Fixtures Screen.
http://www.dynomotion.com/Software/KMotion431c.exe
Group: DynoMotion Message: 7248 From: fireup_kev Date: 4/13/2013
I try to use Set_VarsFile() but it was private, I had to add a public member access in KM_Interpreter.cs
/// <summary>
/// File path for the EMC Vars file
/// </summary>
public string VarsFile
get
return Get_VarsFile();
set
Set_VarsFile(value);
I update the file in the same folder V4.31c
> Hi Kevin,
> Sent: Friday, April 5, 2013 7:39 AM
> > Hi Kevin,
> > Thanks
> > > > Kevin,
> > > > Regards
> > > > TK
> > > > Thanks,
> > > > Kevin
> > > > > Hi Kevin,
> > > > > Regards
> > > > > TK
> > > > > > Tom,
> > > > > > Thanks,
> > > > > > Kevin
> > > > > > > Hi Kevin,
> > > > > > > this
> > > > > > > should be
> > > > > > > Regards
> > > > > > > TK
Group: DynoMotion Message: 7249 From: Tom Kerekes Date: 4/13/2013
Kevin, Thanks!
